Sputtering and lights flickering
Velocity Motors
Oct 13, 2003
Here's some back ground information:
1992 Plymouth Laser RS Turbo
77000 kms
Automatic Transmission
Problem: When driving any speeds ( highway or town ) I am having intermittent problems where the car sputters and looses all power to the point where I have to pull over and put it in park. The RPM's drop and the lights on the dash flicker on and off, but doesn't ever stall out completely. After I put it in PARK and push the pedal all the way down, the RPM's go up and the car is fine for another couple of days/weeks.
Here is what I have done so far:
Replaced the fuel pump
replaced the fuel filter ( engine & the gas tank )
Replaced the plug wires & the spark plugs
Replaced the battery
Any help is appreciated and thank you in advance.
ecu capacitors, my car is stick, but it did the same exact thing, at first i thought massive boost leak, but occassionally it would go away by itself, i replaced the caps and not happened again
Do you have specific instruction on where to look and which caps to replace ? Is it obvious as to which caps to replace and also where is the location of the ECU ?
