Sputtering after returning to stock
Boostdclips99
306
Mar 19, 2006
Roanoke, Virginia
I just finished returning the fuel and engine mods back to stock and now the car is bogging and sputtering at 4k whether I'm full or part throttle. It ran fine a few hours before. I took out FPR, 660s, 255lph fuel pump, and dsmlink. Everything was returned to stock. I changed spark plugs back and connected the fuel pump back to original wiring. What should I look for as the culprit?
Disconnect the battery terminals and re-connect them to reset the ecu and report back. Also check to see if your spark plugs aren't burned out and are correctly gapped for your stock application.
I unplugged the battery for about five minutes to let it reset but no luck. Also replaced the plugs to bp7res with .28 gap...and no luck.
I was going to say get bpr6's, but that won't make a difference, but if you'd like to give it a try then go for it. Also just in case, remember the firing order on the 2g coil pack from left to right/ passenger side to driver side, is 4-1-2-3 in case you might have misplaced a cable.
The car had NGK 6s before I put the 7s in, but it made no difference. I think I have checked the cables a thousand times just to be sure but they are right.
I can hear the fuel pump running so I don't believe it is dead. My guess is either the FPR or ECU.
