2G speedo issue
gst fat
284
Jun 22, 2007
Miami, Florida
ok so i have had my car for 5 years now and since ive had it its never read my MPH,i never really cared since the the rest of the cluster has always worked.
this is what ive done to try and fix the problem ive changed the cluster,ive changed the speed sensor as well. again everything on the cluster works excepts the MPH, i honestly dont get it the car runs flawlessly and has no electrical issues, is there something else i can do?
btw its a second gen 5 speed gst
This one should be fairly easy to figure out, if you have a standard test light......
First step, connect the lead on the test light to power. Now disconnect the VSS.
Test the black wire (at the connector terminal). Does the test light illuminate?
If no, run a wire from that terminal to chassis ground and take it for a ride.
If it does light.
Connect the test light lead to ground and test the black/white trace wire. If the test light doesn't light, you have an open circuit in the power supply to the VSS.
If everything else on the dash (tach. temp. gauge, and fuel gauge) works, then the ignition switch circuit is ok. You have an open between the ignition switch and the VSS. If the test light does light.
The last test is the circuit between the VSS and the cluster. The easiest way to test it is with a DVOM (Digital Volt and Ohm Meter). If you have one, set it to ohms and connect one lead to the yellow wire at the VSS. Pull the cluster out and connect the other lead to pin #36 (yellow/white trace wire)
If the DVOM shows around 0.5 or less, you must have skipped one of the other steps or the tach/VSS is no good. If you think it's the tach/VSS, let me know and I can give you a simple test to find out!
If it shows 0.5 ohms or higher, you have high resistance in the wiring from the VSS to the cluster. The easiest fix would be to run a new wire between them. If it shows OL, the wire is broken somewhere in between. I would run a new wire directly to the cluster, soldering and heat shrinking both connections.
That is the entire system which is fairly straight forward. Any other questions, post back or pm me for more info.
If it does light....
If everything else on the dash (tach. temp. gauge, and fuel gauge) works, then the ignition switch circuit is ok... you have an open between the igniton switch and the VSS. If the test light does light....
The last test is the circuit between the VSS and the cluster. The easiest way to test it is with a DVOM (Digital Volt and Ohm Meter). If you have one, set it to ohms and connect one lead to the yellow wire at the VSS. Pull the cluster out and connect the other lead to pin #36 (yellow/white trace wire) If the DVOM shows around .5 or less... you must have skipped one of the other steps or the tach/VSS is no good. If you think it's the tach/VSS, let me know and I can give you a simple test to find out !
If it shows .5 ohms or higher, you have high resistance in the wiring from the VSS to the cluster. The easiest fix would be to run a new wire between them. If it shows OL... the wire is broken somewhere in between. I would run a new wire directly to the cluster, soldering and heat shrinking both connections.
LOL thanks sounds easy but lets see i hate doing electrical ill keep you posted hopefully i have time tomorrow
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
