speed density IAT sensor wiring
talontuner1997
148
Oct 19, 2006
St. Catharines,
I had a question regarding speed density. I read the instructions on this site, which tells me how to wire up the GM IAT sensor.
sdsetup [ECMTuning - wiki]
It says to cut the black wire and red wire with blue stripe on the MAF harness. After looking at my MAF harness i found the all black wire, but i have no red with blue stripe. I have a solid red though. Is the solid red the one i should be using? or does anyone have a diagram of the connector and which wire number in the harness i should be using.
Pin 6 is the one you want to use. you can use the same ground you're using for your map sensor, or Pin 5.
