Spark Plugs and Florida Heat
shinzon
349
76
Sep 11, 2006
St. Petersburg, Florida
My Talon tends to run like shit (down on power, engine generally feeling tired) during the extreme heat of Florida summers and I was wondering if switching from a BPR6ES to BPR7ES during the summer would help the engine run better. Any other suggestions on what I can do to help combat the weather conditions would also be appreciated.
The car is lightly modified. 14b running stock boost level on a stock fuel system and with the stock side mount intercooler.
the air is hottewr now, so there is less O2 to be burnt/mixed with the fuel
a bigger intercooler will do more for you than a spark plug change.
Thanks for the reply. I am aware of the difference in air density due to ambient temperatures and a front mount is definitely on the agenda at some point, however I was wondering if there was something simple (read: cheap) I could do to get it to run a bit smoother in the short term.
The car has trouble idling sometimes; usually on days where its cool in the morning when I shut the car off and hot in the afternoon when I go to start it again. It clears up after I increase engine revs for a few moments. My theory is the fuel trims are off because of the temperature change and I'm running rich.
about the only cheap thing I can think of is move your windshield washer sprayer nossle down to your IC so you can spray water over the IC......
well running a 0w-30 in the summer will help reduce friction which reduces heat also in the summer draining your coolant and only run water it makes it 50% better at cooling and if you dont like that idea becasue of the lubricationg properties of the coolant then you can add a product to the water called water wetter to add the lubricant and help the water dissapated the heat better good luck
