Upgrade Spark Plugs and Wires?
jwahl16
427
3
Oct 26, 2009
Havertown, Pennsylvania
So right now i have BPR6EGP spark plugs that need replacing. I am going to replace the wires. I am going to have a few mods on my car: 16g turbo, new o2 housing, injen intake, few other things. should i upgrade them or buy stock? If i should upgrade, can you provide links to the parts? Thanks.
NGK standard BPR6ES or BRP7ES depending on boost and NGK wires thats it. No fancy platinum or triple prong plugs just the standard copper ngk's. NGK wires are the wires I've had the best experience with. I had the giant Taylor 8.5 mm wires but I switched back to the NGK's, they fit better and do the job as good if not better.
should my local autozone or pepboys sell these or do i need to order them online? Thanks
You can also look a Magnecor wires. I have had them on my talon engine for a couple of years with not one miss. I have had issues with another turbo car I own with expensive "put together wires" burning out the ends with an MSD 7 . Tres...
Do i have to buy these online, or can i get them at my local autozone etc.
Ok so i got the plugs and wires from pepboys today.
As i was gapping them i noticed he gave me one different spark plug then the others.
3 were: NGKBPR6ES
the other one was: NGKBPR6ES and it had an 11 under it (on the box). On the spark plug itself the serial number is the same. Will these be compatible with eachother or should i take it back?
Thanks
