Spal Flex-a-lite how to?
danielsl1999gsx
847
93
Jun 5, 2009
los angles, California
Hey guys, need some wiring gurus to chime in here. I just bought myself a dual Spal flex-a-lite fan and shroud in preparation of summer. I currently have one 10' and one 12' but burned one on the way down from SF. Needless to say i need to change these out asap. My question is how do i wire this? My current set up has both fans wired into one OEM plug that connected to the passenger side. I got two oem fan plugs but dont know if i should wire each Spal fan to one plug or due the same thing i currently have (never had a problem with this). The spal fans also just have a black and white wire.
Also it came with this black controller box? Not sure what to do with this, but from my research no one uses this. I posted some pics to help you guys out with what im dealing with.
Easiest thing to do is cut the connector off your factory fan and wire the fans in series, the solder them to the connector. BAM! Plug and play and operates like factory.
That's exactly how mine are setup.
Its really simple. The fans have two wires, depends on how you wire it the fan will either push or pull. You can use a 9v battery to test it so you'll know which wire does which. One is your neg one is your pos, again just depends how you have them is how the fan will operate. The plug (factory) has 2 wires as well, you can find a wiring diagram online to tell you which wire is which if they aren't black and red.
