space pivot ball
fncrazy
74
Jul 28, 2012
maple shade, New Jersey
Ok I was just wondering if with a new ball and fork will I need to shim the pivot ball. I'm going with the forged fork and ball from extreme psi. I ask cause this trans is a bi*** with the dam polyurethane mounts LOL thanks.
luv2rallye is right. There's no real way to be sure until you get the trans onto the motor and check where the fork sits. If all of your drivetrain components were brand new, I'd say your chances of needing to shim would be slim to none. If the clutch is pretty new, I think you'll be fine.
Yea the clutch is pretty new act2600 came with car and I swapped out my trans with a 93 cause my old one grinded second. And well I had it out and said I should shim this wait the other trans was fine....... f***ed myself with a low pedal and clutch drag so I want to do it right this time LOL thanks for the advice
