sounds like a leak.But it's not..i think
miliman13
2,496
696
Jan 1, 2011
tampa, Florida
hey. it sounds like intercooler pipe leak/ un plugged MAF . but its not. and seems to happen on open loop. or when i hit 55mph... ...but not on idle.... like this other guys post it sounds like a suburu..... if this has happend to you. share some wisdom:hellyeah::hellyeah::hellyeah:
http://www.dsmtuners.com/forums/newbie-forum/435513-help.html#post152971597
also looking for the slimmest and most freaking powerful a/c fan possible cant use stock wont fit with my mods.thanks
Get a boost leak tester and pressurize the system, I actually once had a squealing noise coming from one of my couplers on the front mount piping. I checked everything over and over but found the leak when I pressure tested it.
start at the throttle body, then move down the IC piping one section at a time. This will help pin point all of the leaks use soap and water to make the small leaks more visual. Dont forget these test are best done at 40 deg before top dead center timing so the intake valves are closed FYI.
