someone with service manual please help...
dyablo
250
Jan 22, 2005
Indio, California
So I bought an a/c compressor, receiver/drier and the expansion valve. I know where everything is except for the expansion valve. Could some one please help me identify where it is? I searched and came up with the conclusion that its located behind the glove box but thats about it. THanks.
Under the dash behind the glove box you should be able to see a rectangular box which houses the evaporator...the expansion valve is connected to two lines and sits just about in the center of the evap box....not sure if its inside or outside of the box though) Ill try to get a picture up for you...
well I tried to take the evaporator box out but had no luck. Iwas able to to get a peek thru a hole, and i can see the expansion valve. I just cant figure out how to remove all the stuff back there to get to the expansion valve.
