someone save me...
Blam
186
May 26, 2003
Edmonton,
well...after 3 ISCs, 2 TPS', 2 throttle bodies, a fuel pump, EGR block off, and gasket replacement, my car is STILL running like SHIT.
it idles fine, with the occasional idle surge. problem = when put into neutral from any speed higher then 1100 RPM it stalls. moving or not moving.
does anyone know what the hell is wrong with my car? it's been driving me NUTS for 3 weeks now. :( :mad: :cry: :confused:
Sounds like a vac leak. Check all soft IC piping to make sure there are no leaks. Remove and retighten if necessary. I'm sure someone on here can tell you how to do a pressure test. I don't know how to.
I retightened them today. I will do a test later today since I really have no other options right now
