save me, im a retard
mygsx2120
353
Jan 4, 2006
Newark, Ohio
I read the instructions on how to install a blowthrough set-up on here. It said if you can pick your nose you should be fine. Well, I was having problems getting the car to run right, so I decided just to put back on my stock stuff since it is my DD. Now my car won't start at all.
I think it has something to do with the CAS. That is where I spliced in the RPM wire for the translator. When I went to expose the wire, I sliced into slighty so I just cut it. Could I have a bad connection there? Or could the CAS moved so it is not timed properly?
Please guys, save me from my own stupidity.
Splice the wire you cut through back together, and make sure its making good contact, if nothing start checking fuses and relays.
