someone help
eclipse-gst339
37
Jun 28, 2004
fredericksburg, Pennsylvania
first off if you have any idea or import please let me know. OK here we go. first my dad just had his turbo 4g63 bottom end rebuilt. it was bored twenty over. other than that it is stock. when we got this car (91 eagle talon awd) someone already started tearing the engine apart. we figured most of it out. well enough to get it running. when it is started the only gauges that work are temp and rpm. the other problem is that it is loading up like its two rich or missing on two cylinders. can these things be caused by a vacuum line problem because we think we got it right but are not sure. if you can give me somewhere to look and what could be wrong it would be appreciated. thank you
I have the taboo pics for removing the vacum lines, the first pic is the way there supposed to be and the second pic is with them removed if you want to clean the engine bay up a bit. Hope this is helpful.
If you don't mind, post that as a tech article, would be very helpful to other members. :thumb:
