Some questions about my setup, help please
stealth13
136
Oct 10, 2008
calgary,
I have a 96 tsi awd with
FP big t28, 550 injectors, walbro pump, 3 inch tbe, upgraded intercooler, head studs, safc tuned 18psi, and the rest of the bolt ons.
First question: Can i run 22psi on the 550's with this setup without fuel cut?
second: How much power should it make at both 18, 22 psi?
Third: if you can hear air gushing out from somewhere is that a pretty big boost leak? (my car ran slower quarter mile on the upgraded turbo with more boost then the stock turbo)
Thanks! :thumb:
im not to sure if you will be able to run 22psi with the safc but i would suggest to get an afpr.
if you hear rushing air then yea you most likely have a boost leak.
1. You need a logger of some sort for that answer as every car is different.
2. That is bench racing and not allowed.
3. If you haven't done it already do a boost leak test. Any time you mess with IC piping, turbo or any thing else that sees vacuum/positive pressure you should do a boost leak test.
1.) You should atleast get a logger if you want to run that much boost. Then you can see your idc's rather than just assuming/hoping you will be fine. And if you don't have a wideband, get one.
2.) Who knows how much power...it all depends in your tune, and so many other factors
3.) No boost leak is good!!!!
