Some questions about idle and boost
drk mrk iv
238
Jul 31, 2004
Charlotte, North Carolina
I finally got my car running the other day. When I crank it up the idle kind of jumps around. It almost stalls, but then catches and idles relatively smoothly at 1k. Then it will slowling climb to 1.3-1.5k and then slowly go back down. This happens after I have been driving awhile. And, what is the difference between 12 lbs of boost and 15lbs of boost on a T25? I have hardpipes and 2.5 inch exhaust. 20horsepower? Thanks.
sounds like idle surge...my car does it too I just haven't fixed it yet. A number of different things can cause it. Check the base idle set screw located on the throttle body (<a href="http://members.shaw.ca/dsm.1000q/Engineprimer/1G/biss.htm">here</a> is a good pic of it) if it wiggles around and such or just turns with your finger...that could be part of the problem.
Here is a great write up on how to diagnose idle surge <a href="http://www.dsm.org/how-tos/tttt/tttt3.html">http://www.dsm.org/how-tos/tttt/tttt3.html</a>
The BISS is fine as far as wiggling. I should explain the situation better. It will idle at 1k after a little while and then will creep up to 1.3-1.5 and stay there until I tap the gas and it will fall back down to 1k and be just fine.
  • For sale NEW Magnus Forged Transfercase gears PENDING
    Parts are new never used. Get some nice parts for a couple bucks off.If I don't replay right...
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
