Some Part Number Help
firehawk
169
Oct 17, 2003
Vandergrift, Pennsylvania
Hello all. I need some part numbers or at the least some names for these parts. They are sensors on the thermostat housing. You can see which ones they are....thanks
(also thanks to whosever thermostat housing this is)
For what ever reason I can't even select the thermostat in caps today LOL. So here is at least the names, posted by Defiant in another thread.
*EDIT* I was poking around in caps and I dug up these. I still can't figure out how to select the upper portion of the thermostat housing :mad: .
MD069879 Sensor Unit - Water Temp
MD091056 Gauge Unit - Water Temp
Since I can't get the upper portion of the TS selected I can't find the switch. If one of the wisemen should be able to help out with that one.
that takes care of the top one, the engine coolant temp switch
nevermind i just saw your edit
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
