Resolved need some help with a part number
ASZRAEL1266
895
Oct 15, 2002
Do any of you happen to know what the part number is for the studs and bolt are that hold the turbo to the exhaust mani?
Thanks is that for the stud that goes into the exhaust mani or the bolt that goes from the exahust mani into turbo?
That is what i was thinking about doing. When i called they said there were two diffrent sizes and would need my vin. Are there two diffrent thread counts i would think that all 1Gs would have be the same as we can swap exhaust manis and all use 14B
ICE_T gave you the one and only part number for a 1G manifold to turbo bolt.
The stud is a different length than the bolt because it has to have threads on both ends but they are interchangable. CAPS gives two part numbers for the stud because Mitsu goofed up and labeled both the manifold stud and the 02housing stud with the same identifier.
The correct stud part number is MD050075 but just use the bolt.
Steve
