Some one who has taken apart a head please help!!!
obeypixel
31
Feb 2, 2004
Raleigh, North Carolina
Ok, here is the deal.
Timing Belt broke on my 91 laser RST. So instead of spending the 250 bucks at the machine shop to get the head fixed, I opted to by a used one.
So I get the head off of a 91 mitsubishi gsx, and I put the cams from the old head into it. (it didn't come with cams). When I turn the cams to see if all of the valves work, they hit each other...the intake and exhaust valves.
Now not knowing a whole lot about this engine, I put the question up to you guys. Is that ok. I mean, is that normal, that the cams will push the valves out to the point that they hit each other? If not, do the cams not fit the gsx engine?
I thought that all the turbo engines were the same for the first gens atleast.
Thanks ahead for the help guys.
-Brandon
thanks a bunch, now for my next question.
I suppose that the cams need to be in a certain position when I put the timeing belt on. I have Chilton's at the shop so I will check it.
But unless I am missing something, its just a simple matter of putting the timing belt back on with the cams in the right position, and then adjusting the CAS.
Anything you all can think of that I need to be aware of... I really don't want to F*ck up my engine again.
Thanks
-Brandon
You want to make sure that the crank is aligned so that the first cylinder is at TDC, and the dowel pins on the CAMS are in or close to a 12 o'clock position.
