Some of the most vital MD part #s
2GturboTALON
607
6
Nov 26, 2002
St. Peters, Missouri
I came across this list and have yet to see one like this on here. A lot of these are very frequently used and asked about parts.
MB599233 Clutch pedal/shaft
MB599879 Clutch pedal lever that connects to spring and master clutch cylinder.
MB606048This is for the key/column side wire harness (1G)
MB521556Speedometer cable for a 1g TEL
MD608806 THROTTLE BODY O-RING (1G)
MD146399 Mainifold to TB gasket
MD340327 TB elbow to TB gasket
MN143460 Oil squirter
MD171220 EVO3 7cm Manifold to Turbo Gasket
MB539465 1G Non-Cruise Throttle Cable
MD141456 Black T_Belt cover This is for the 6 bolt motors, Lower piece
This is the oil filter bracket from the 2.0 truck that will eliminate the oil cooler. It will also relocate the oil filter away from the downpipe.
MD122260 Bracket
MD149370 Gasket
Mitsubishi Truck 2.4L filter bracket assembly...the above is for 6-bolt engines. I believe the gasket part numbers are the same as the stock gaskets.
MD189888 Filter Bracket 7-bolt
MD308197 95+ exhaust manifold
Turbo to mani studs/bolts
MR187699 bolt
MR187848 washer
Balance shaft elimination kit
MD103722 Bearing
MD040597 Bearing
MD092785
MD098626
Balance shaft elimination gasket Part numbers
MD183240 Oil Strain Gasket
MD185528 Oil Filter Gasket
MD258477 Turbo Charger Oil Return Gasket
MD187905 Front Cover gasket
MD997740 Mitsu liquid gasket for oil pan
MD970389 Better stuff is
MB367321 coil/spring that returns the shifter
Shim plate clips for GSX/3000GT
MR389607 Fronts
MR389629 Rears
161km02 2g gst apexi n1 3in exhaust
MD611831 91 46g3 CAS O-ring
Summit Racing 4G63 engine mounts
13-2001 Summit racing part# ptp-13-2001 Full kit 2G
13-1901 Summit racing part# ptp-13-1901 Motor mount kit for 2G
13-1902 Summit rcing part# ptp-13-1902 Motor mount kit 1G
Injector seals Felpro part No. ES 70600 (fuel rail side)
MD087060 x 4 injector to head seals
MD614805 x 4 injector to fuel rail seals
MD614813 x 4 injector o-ring seals
MD125939 Valve Cover (Rocker Cover) Gasket:
MD125940 x 4 Spark Plug Gaskets
MD050536 Half-Moon Gasket
For 95+ models...
MD186784 Rocker Cover
MD186785 x 4 Spark Plug
MD050536 Half Moon
MD153103 x 2 Cam Seals
MD184946 Rubber Plug (intake cam)
ostbody >MB527995 Heater hose kit (feed and return + clamps)
MB356992 Radiator hose, upper
MB605486 Radiator hose, lower
MD140477 Water hose
MD163197 Oil cooler water hose, upper
MD169143 Oil cooler water hose, lower
MD167360 Turbocharger water hose
MD146803 Throttle body water hose
MD017335 By-pass water hose
MD130457 Upper thermostat housing
MB660735 Radiator cap
MD145038 Lower thermostat housing to head gasket
MD363392 Oil cap
MB948632 2G non cruise t-cable
MD326059 1G/2G 4G63t timing belt
MB154554 Spider Kit, Propeller Shaft Uni
MD719165 Metal shifter bushings (GVR4, Eclipse/Talon/Laser)
MR389655 91 front brake pad shim. They come in a set for the whole front (Lx+Rx)
MD308197 2G Exhaust manifold
MR188003 2G O2 housing
Service manuals
MSSP102B90 1990
MSSP002B91 1991
MSSP002B94 1992-1994
MF650102 Oil feed bolt. (banjo)
MD349347 4 Layer Metal Mitsu Headgasket
MB439488 Blower motor switch (2G only)
Front cover oil pump gears " turbo models only"
MD121120 Big Gear
MD125361 Small Gear
BISS Cap:
MD61450 ('90-early '92), MD614532 (late '92+)
BISS:
MD614948
BISS O-Ring:
MD608806
MD998767 t-belt idler bearing tensioner tool
MD040557 flywheel bolts
MD326852 Crankshaft Sprocket
MD074255 Crankshaft Pullet Bolt
MD01245 Crankshaft Pulley Washer</SPAN>
Waterpump kit
MD972052 pump, o-ring and gasket
MB911495 Wheel Stud (1G or 2G, AWD or FWD)
MD175762 6 bolt oil pump (case) MD174581 (gear) MD174582 (gear)
MD327450 7 bolt oil pump (comes w/ gears)
MD125376 front case plug (funny shaped screw-in plug right next to the oil pump sprocket
MD041021 front case plug o-ring
ME581050 Friction modifier (follow this link for more info)
MB059359 downpipe to 02 nuts
MB5054 front and rear carrier bearing (AWD 1G driveshaft)
MR111611 driveshaft yoke
MD749998 2G throwout bearing
MD141510 Knock Sensor
MD326059 Timing Belt
MD164533 Hydraulic Tensioner
MD183609 2G MAS
MD188995 1G metal intake manifold gasket
>EGR Block off kit
MD103510 EGR blockoff plate
MD183535 EGR gasket
MF240051 x 2 bolts
MD188208 91-94 02 sensor
MD724458Clutch slave cylinder (from Rubber hose near Trany to slave Cyl.)
MD733623 1G clutch slave cylinder
MD997607 OEM Mitsubishi 180f thrmostat
MD749823 2G slave cylinder
MB555133 1G master cylinder
704-1037 02 sensor plug from NAPA
MD312865 2G plastic dipstick (will work on 1G)
MD075834 x 2 Just the Upper O-Rings
MD313819 2G 02 sensor
MD184529 93/94 crank angle sensor "black cover"
FEL-PRO 60496-1 NEA EX-924 2.5" exhaust flange gasket
MD749998 1G throwout bearing
MD770506 Clutch fork (all 1G's)
MD974635 top end gasket set (1G)
MD974636 overhaul gasket set (1G)
Big brake kit
MR389548 pads
MB928319 rotors
MB857838 3000GT Left Caliper
MB857839 3000GT Right Caliper
MR389599 Pad Clip Set
MR389652 Pad Shim Set
MD311230 early '90 02 sensor
CAPS breaks the numbers at 4/92, so I'm guessing it's a 6-bolt / 7-bolt difference... Check your exhaust studs to make sure.
8mm studs:
MD005317 x 9 Studs
MD041192 x 9 Washers
MD092806 x 9 Nuts
10mm outer studs, 8mm inner studs:
MD146938 x 2 Outer Studs
MD050076 x 2 Outer Washers
MD165879 x 2 Outer Nuts
MD005317 x 2 Inner Studs
MD041192 x 2 Inner Washers
MD092806 x 2 Inner Nuts
1G FWD/AWD diff. axle seals
MD707184 Build Dates 5/88 - 6/92
MD742053 Build Dates 7/92 - 5/94
MD173425 6 bolt AWD flywheel
MD349347 4 layer Metal Mitsubishi headgasket
