Some kind of noise
TheAButton
53
Jul 7, 2008
Selah / Yakima, Washington
OK so I don't really know if I even have a problem because I may just be a worry wart knowing I drive a DSM and am just waiting for the slightest thing to go awry. But what i have noticed is i get this weird noise part way through spooling, that kind of sounds maybe like a bearing or something of the such, the sound too is a deeper tone, but not a grinding. Also though it dose seem like when driving I may be losing some top-end power, but not a lot. I have done a compression test on my car, i got like 165-170 across the board. So my thinking is maybe my turbo is going out, but what scares me most is i don't think I would be able to tell if one of my rob bearings would be going out and what it might sound like.
It doesn't actually sounds like a wine, more like a rapid vibration, or something. The turbo did have a little shaft play when i put it in, so I can only see it getting worse (can't check it right now though)
I've been getting a strange sound as well. Does it almost sound like a raddling sound or like some bolt flying around against objects only under certain RPM zones? I have been getting a raddling sound only around 2.5-4k rpm and it seems to be coming from either the belt or the turbo.
I even took off the timing belts heat shield to make sure, and the timing belt is plenty tight, and the raddling stillehappened so it's not hitting against the heat shield.
