Some General Info Needed
Status
Not open for further replies.
Astraoid
Sep 3, 2004
Plymouth (UK), Europe
Hi, I have a Vauxhall Astra (I don't suppose many of you guys know what that is) which has had an engine conversion - C20LET - Which is a 2.0L 16v Turbo. Some 2 years ago, I replaced the stock turbo with a K26 Race Turbo, which was good for around 350whp. The car was built to run much higher power, but the software only ran a 370whp map, so the turbo was pretty much right for it's application.
I've recently changed the management to Autronic SMC, so I can now start to push the power up. I've changed the turbo to a PTE SCM50 which, to my knowledge, is a first on this particular engine (mainly due to the fact that they just don't fit easilly into this particular car). I know that they're a relatively common choice for a DSM, so I'd just like to make some comparisons to the engines you guys run.
First of all, what is the stock spec of your engines?
Any gen would be useful guys:
Compression ratio,
Engine Capacity,
Valves per cylinder
No of Cylinders
Standard power output?
etc...
Status
