general cylinder firing info
jt1583
86
Mar 24, 2004
alpharetta, Georgia
on most cars, does more than one cylinder fire at a time? when i say fire i mean combust gas when its on compression stroke, not the thing for emissions. thanks
Engines fire at the end of compression stroke, and only one fires at a time, which is why there are proper spots on the coil pack for each cylinder (i.e. 4g63 = 4 - 1 - 2 - 3). There are no cylinders that even run the same spot in the same stroke. When one is on compression, the other one that's in the same spot is on exhaust.
DSM ignitions are like 4-cylinder motorcycle motors, in that they fire off two cylinders at a time. One of the pair is on power, the other is on exhaust. It's not for emissions, it's not for power, it's just a tidy way to set up a four-cylinder engine's ignition scheme. It's a waste spark. Saves you needing a distributor and all the jimcrackery entailed in driving and mounting it, and all its parts.
It's a fairly new "innovation", leaving dozens of old-time ignition engineers with bruised foreheads from where they've slapped themselves and said, "Why didn't I think of that?"
