So I bought a 95 talon and the alarm goes off for no reason
everglow
66
Jan 24, 2005
Apple Valley, Minnesota
So why does this happen? I heard someone say something about door switches going bad? When I open the doors the lights don't go on but I think they do when I close the door after it was running. Also I am not sure if this always happens but if I lock the car from the pasanger door I don't think the security goes on
you have a short somewhere in the wiring. go get a new alarm hooked up by some pro's and just have them rewire everything.
I had the same problem and it was the switch that turns your lights on when you open the doors. I just unscrewed mine and unhooked the switch, screwed it back in, problem fixed.
where is this located and any chance you can draw on a pic of where to do this?
I had the same problem on mine, It ended up being the hood pin in the engine bay. I just bent it up some to is make good contact with the hood when it was closed and I havent had the problem since.
Yep, what they said. I had the same problem. I put a couple washer under where the hood pin mount is and bent it up a little. Problem solved. :thumb:
hood pin? As in the thing that when you pop your hood you slide your fingers under and move it to open? Or what is it?
Defiant said:
You..... you can't find the door switch? :rolleyes:
It's the rubber button at the rear-bottom corner of the door frame.
Goooood luck.
Ah, didn't think I would have to pop it out.
