So got a question about 4g63 n/a
25psi_talon
75
May 28, 2009
Cedar Falls, Iowa
so i swapped a 4g63 n/a into my colt the donor motor was out of a 91 talon that ran flawlessly.... the problem im having now is that i can get my car to start... sometimes... but only when im on the gas... it revs fine but when i drastically let of the gas the car back fires and slowly dies.... but i can not get it to idle at all.... i have replaced my fuel filter, put a walbro 255 in and have all vacuum lines ran.... what could be my problem?
the only thing i can think of is my mpi relay is out of a 94 n/a
i would check the coolant temp sensor. see if you can get a logger on it to see if you can pull up any trouble codes. just a thought
You also need a different FPR. The 255 is too much for the stock FPR and can over-run it. THis will make you run real rich.
