I got a quick question about valve seals
dsmoverboosted
217
Feb 26, 2006
Winnipeg,
Are the intake and exaust valve seals different or are they the same? I found a freat deal on some valve seals but the guy says all 16 are the same. Thanks
If it helps, I just bought new ones for my son's 1998 GST from the dealer. All 16 were the same part number, according to CAPS.
I found a vin# on autotrader for a 1991 Eclipse and used that in CAPS. Both intake and exhaust valve seals had the same part number. It was even the same part number for my son's 1998 GST. Your 1991 Talon probably uses the same ones, but double check with the dealer first. I don't think CAPS works with vin#'s from Talons, otherwise I would have you pm me your vin# and I could check for sure.
Mike
anyone else got any thoughts on this? so i should get these ones then
