Small FMIC w/ oem foglights?
94exa2
184
Jan 1, 2010
Atlantic Beach, North Carolina
So, i was wondering if anyone knows of a FMIC/piping kit that retains oem 2GB foglights...seems like you have to get rid of the fogs for most FMIC....
As does the punishment facing FMIC kit...I know i need to trim my bumper cover a little bit more to otherwise put it on but heres a pic for you...you can see my fogs in there....once I trim it itll be ferfect....and look correct....
I have the SBR kit and kept my foglights. Had to hack the stock foglight mounting brackets to fit. Prior to this FMIC, I used the Hahn Racecraft FMIC and also kept the stock foglights with no hack required.
I have a greddy style fmic i can keep the fog lights where they are.
Also JFZERO does that fmic require you to move the evap canister, because im looking for a bigger front mount but the other one i have wont work because thats in the way..(i guess its only in that spot for 2gb gsx's)
Yes does require you to either remove or relocate the charcoal canister....I removed it either way....
I'm going to remove all my emissions eventually anyway...and since I dont feel like modifiying anything I just removed it....Link will make sure I dont have a CEL for it when I eventually get the money and buy it....
Damn.. i dont want to remove it because of emissions and i heard it makes your car reek of gas smells. i was thinking of just moving it to the passenger side if i could, I think i remember hearing about someone doing that
I ran a generic SSAC 24x12x3 core and was able to keep the oem fogs. I now run a 26x12x4 ARC core from an EVO with no problems as well. Just depends how you have your ic pipes routed.
are there any that let you keep fogs on a 2ga front bumper w/o hackin stuff?
ebay fmic and piping kit
No corey he left the SMIC on there and told people he ran two intercoolers..Its got that WOW factor LOL..
You could always go with the Supra SMIC, but that's just a suggestion..
That's what I was thinking. ROFL
The Supra SMIC does need some modification to work on a DSM. I beleive it needs the top end tank rotated in order to work.
