Installing OEM Foglights on RS
Should be a fairly simple deal. I was gonna do this at one time and my plan was to just but a used stock fog light switch off eBay and just run my own wiring. Should just need a wire from battery to switch then a wire from the switch out to the lights. If the lights need a ground you should be able to ground them anywhere around there that's metal I would think.
If the wiring doesnt exist, the easiest way would be to get the foglight connector pigtails and the oem foglight switch from the junkyard. Then get a foglight wiring kit, which usually includes all the wiring, relay, switch (you will use the oem one), and instructions. Wire the kit per instructions using the oem switch and pigtails.
