Small 16g fit into a 14b comp and exhaust housing?
805eclipse
159
Jul 16, 2003
Newbury Park, California
i have the center section of a small 16g and i want to know can i put both housings from my 14b directly on it then bolt it back up to my car with no problems? ### get back to me asap ### i kinda allready started the project.
Your 14B turbine housing will fit although the smaller 6cm size will hurt top end flow. The compressor cover, however, will not and will either need to be machined to fit or you'll have to purchase a 16G compressor cover separately.
Hope that helps,
Andy
Check the vfaq website, there is a turbo rebuild section there that a guy shows picture by picture rebuild using a 16g center section in a 14b.
