sm 16g and pr fmic install question
dsm2race
77
Sep 17, 2010
stockton, California
well i just installed my small 16g and my punishment racing frount mount tonight my question is do i put a t from the wastegate and the nipple on the ic piping? my t25 wastegate and turbo nipple where t together then ran to the bcs.so do i do the same with the sm 16g and the nipple on the fmic piping?
Wastegate > Boost Controller > J-Pipe
BOV > Intake Manifold
There will be no T's.
I see what your asking. Yes keep it Tee'd together and one goes to the wastegate and one goes to the J pipe.
The only difference is that before instead of the j pipe, your compressor cover had the nipple.
If you ever want to up the boost, here is how a boost controller works. goodluck.:thumb:
I see what your asking. Yes keep it Tee'd together and one goes to the wastegate and one does to the J pipe.
If you ever want to up the boost, he is how a boost controller works. goodluck.:thumb:
yeah thanks i did have it right just wanted to make sure :thumb:
No, you don't need a boost controller, you can run the hose straight from the j-pipe to the wastegate and run wastegate pressure.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
