Slowboy Racing MBC
dizasta72389
30
May 18, 2006
Manchester, New Hampshire
Okay after searching around the Slowboy Racing Website and here and found nothing. I am wonder how I will set this up. I know about hooking it up but setting it to proper boost.
Do I tighten it all the way down then every 1/4 turn = 2PSI or what? Because I don't know because I have never used the SBR MBC. They also didn't send any hoses with it so what kind of hoses should I use? Just silicon ones from AZ or what? Also I heard the it would be better to connect one of the lines to the Lower IC Pipe, instead of a T Fitting on the Vacuum line. Could someone give me the link for it on here?
Thanks a bunch guys in advanced :)
Screw the MBC out. Then slowly screw it in. Every MBC is different in how many turns will adjust PSI. Best bet is to go from the wastegate to the nipple on the compressor housing. Eliminate's a lot of line and spiking.
