slim fan on a 2g
geno414
440
4
Jan 13, 2011
Milwaukee, Wisconsin
Hey every one well on my 2g none of my fans work and that's:confused: a big problem but i found out i can turn on my ac fan because i took my ac out and the fan still turns on . But the fans i have are very very bad and old so i went on eBay and looked up fans and saw "slim fans" well they seem cool but there are only two wires and on the stock fan it i think has three so what do i need to do if i buy a slim fan and what is a good slim fan i see a lot on eBay thanks.
ya there is only 2 wires. a ground and a power.. and there is 4 wires on the stock fan harness.i spliced my power wire into the white wire on harness if i remember correctly and the ground i spliced it to the white/black. also if i remember correctly. LOL..but i will check tomorrow because im not around my car right now.
Good luck cooling with those fans. If you are going aftermarket get SPAL fans. The ebay ones don't blow nearly enough CFM. Stock fans below roughly 1600 CFM per fan.
You should try to find the issue before getting new stuff.
