slave cylinder sizes
DSM "BISH"
241
Sep 10, 2008
Erlanger, Kentucky
okay in my parts system at work we have three differnt part numbers for my eagle tlaon's slave cylinder. 1992 model. i think my slave cylinder is what is causing my clutch engagment problems so i was wondering if there was differnce between the slave cylinders?
I don't think those would be different parts since the 1g's used the same 4g63 for turbo and non turbo. Have you check the position of the clutch fork and pivot ball?
yea its right on the money. i pulled the little dust boot off my slave the other day and felt down inside of it and i dont know if its from where i bled it a lot but the inside walls of the bore were wet? so i think it may be leaking there around the piston allowing just enough air in the system for it to not properly disengage?
what you think about this scenario?
