Slave Cylinder and Fidanza 2.1 clutch kit?
tph1999
Jul 24, 2008
Tempe, Arizona
Hey guys, I'm going to put a Fidanza 2.1 clutch kit and their flywheel on my '95 GSX this weedend and I was wondering if I need to change the slave cylinder at all or if the stock one will be ok.
Also, do I need to do anything to the clutch lines?
Thanks.
pull back the rubber boot on your slave cylinder and see if there's any brake fluid leaking if so, replace it, i think a new one is only like 50 buck or something.
as for your clutch lines i would remove your stock line and replace it with a ss line. by doing this you will remove the hydraulic restrictor and have a faster response after each shift, the line is only like 30 bucks.
