Slave Clutch line Help
Ceezdsm99
108
17
Mar 11, 2022
California
Is this part from STM a replacement for the hard line that runs from the slave to the cylinder ? I have a leak from that line and I can’t replace the slave with the stock line it could break .. would this fit . It looks like it deletes the part from where my stock line leaks from .
The part you have pictured is the line from the slave to the fluid pressure balancer thats on the front of the transmission above the fill plug
You should replace the slave cylinder as well since you are replacing the line.
I had to replace the clutch master, the line, and the slave all within a few months of each other
I bought the full line off ebay that goes from the master to the slave when I did mine
