size of the gam gear bolt
chad6159
78
Oct 26, 2010
findlay, Ohio
pretty straight forward, what is the size of the cam gear bolt? mine broke and need a replacement. could not find this information anywhere any help would be appreciated! thank you in advance
so 12m 1 and a half inches long what does the 30 stand for? how thick it is? l
and thats for the one that goes on the gam gear into the cam shaf right?
ah thank you guys alot!
ya. when i said 12mm head and 1.25 inches long, thats metric and standard in the same thing haha had a brain fart.
Got her runnin again! but timing is messed up. idles rough. Sounds like i have 272 cams in it or something haha. what could that be?
Seems like a silly thing to ask. If the timing is messed up, the car will not run correctly. Fix the timing and go from there. Make certain your balance shaft and oil pump are correctly timed as well.
Timing Belt VFAQ (Timing Belt TSB - ENHANCED)
i was wondering what part of the timing you guys thought was messed up because we checked everything multiple times, we were thinking the oil pump thing too
welli bent 2 valves so after i get those replaced ill see if we can get it but that would explain the idle and the wierd vacume readings.:notgood:
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
