ECMlink Simple MAP Sensor Question
JayB12
544
Jan 12, 2009
Philipsburg, Pennsylvania
I'm going to buy an AEM Digital boost gauge (35psi one) and they come with the boost sensor, I was wondering if I could use the 0-5v analog wire and log it in ecmlink like a map sensor from the MDP spot on the ecu, similar to how my wideband is wired. Also, if this will work, I wanted to do SD down the road and I was going to use ecmlink's kit and the plug and play harness they sell as well. I wasn't sure if I would have issues? Sorry, it seems simple but I wasn't sure.
On a side note, which pin do you guys wire your widebands to? I did mine for my 2g on the rear o2 and 1g's don't have them.
Yes, you can use it to log boost, but I read over on the link forums that one user got direct advice from AEM NOT to use the same signal to run SD. Also, on a 1G you can use the EGR Temp, or Baro input for the sensor.
Yes, I contacted AEM and the signal is no good for SD after its been processed through the gauge.
For speed density, use the silver sensor and not the brass sensor.
Here is what Tom from ECMTuning said when I asked.
It may be possible to use the AEM sensor for SD operation too, though. You just have to manually define that sensor's mapping for SD operation (separate from logging/display) using the "user defined" option in the ECU Inputs tab for the MAP sensor. It's a bit more work, though. And you'll need to make *sure* the AEM sensor is providing an absolute pressure reading instead of gauge pressure.
That's what the AEM tech told me. There is a reason the brass and silver sensors are about $80 apart. The silver more accurate and the specs can be found on their site.
I see.
Thanks for the reply, going to research now.
Brass 5 bar
Sensor Performance Specifications:
Accuracy: +/- 3% Full Scale over -40C to 105C includes Repeatability, Hysteresis and Linearity
Operating Temp: -20C to 105C / -4F to 221F
Burst Pressure: 150PSI
Response Time: < 1mS
Wetted Materials: 304L & 316L Stainless Steel
Vibration: 100 to 2000Hz, 20g Sinusoidal, 3 Axes
Weight: <85g
Supply Current: <6mA at 5 Vdc
Output: .5 to 4.5Vdc Linear
Transfer Function: PSI = (18.75*(Voltage))-24.075
Elec. Termination: Integral weatherproof connector, includes mating connector & pins(Supply Voltage 5Vdc +/- .5, Ground, Output)
Stainless 5 bar
Accuracy: +/- 0.5% Full Scale over -40C to 105C includes Repeatability, Hysteresis and Linearity
Operating Temp: -40C to 105C / -40F to 221F
Burst Pressure: 750PSI
Weight: <85g
You can see the large difference in accuracy.
