Should my bov do this
bob123131
457
Dec 20, 2004
winona, Minnesota
So during boost leak test my bov lets otu air past 5psi like all the time so i cant here for other leask and its hard to build pressure let alone keep it. So if its doing this now its prolyl alwyas doing it right. Also lower back nipple on the my greddy type s can be free or ran a vacume line to somewhere connecting to turbo now i want to do this but no exactly sure how to anyone now a post or anythign with pictures. Also should my bov not let out this air. Lets otu at nipple and at little hole under recircualtion pipe.
the lowre tubnig vnet lein wlill ofnte casue oen of teh nploppel gnosorzg to lsoones off tne uepper hnarness.
You need a new BOV, as well as a new keyboard that has the keys in standard order.
Anyhooo, if your greddy BOV leaks at 5psi, although I don't have a greddy, I hear you just need to add washers or god knows what else, just get a 1G bov and crush it. Costs less and performs just as well (up to 20 psi or so)
ttyl!
Hey thanx i think i will just get a new hks or greddy type r. Does anyone know that answer to my second question. I could really use pictures of where to hook bottom nipple line to so i can try that thanks. Also the reason i cant type worth crap is because im on my work comp and they wont allow any pop ups even spell check and i cant turn it off. From now on i will try harder to find all mistakes.
Before replacing your nice expensive BOV, try setting it more to "hard". Alot of people experience problems with BOV's that are set too soft.
