should both fans be on simultaneously?
wkg96rs
Apr 18, 2005
frack, Pennsylvania
just a quick question; should both radiator fans be on at the same time? ive only ever seen my passenger side fan going... that doesnt seem to make too much sense to me. i checked the fuses and theyre all fine. i also cleaned out the connectors that are going to the fan with hrc electric component cleaner spray... maybe the fan motor's dead?
it'll only come on at certain tempuratures, or if the AC is on.
yep, if you push your AC button in, and turn the fan on, the one on the driver's side will turn on too, i guess you can wire the 2 together so they are on at the same time, i was going to do that whenever i find what wires you have to splice together.
