Shorted some wires and nothing is working proplery
mitsumikey
431
32
Mar 18, 2007
Windsor, ON, Canada
Part 1
While cutting out the passenger side rad support to get FMIC piping through, I accidentlily drilled into the wiring harness a few times. Took a chunk out of 2 wires. I m so pissed because I knew where it was and I was trying to be super carefull, but I definately got 2 wires and sparks flew. They were both white, and thicker than most of the surrounding wires. Now I have to keep my horn relay out because whenever I start the car it would come on in full force, the headlights will not turn off unless I pull the relay, and seem to turn on with ignition, even when the switch isnt used. Foglights, security/power locks dont work, and the HVAC/interior lighting doesnt work. The guage lighting and windows/sunroof however do work. AC seems to be working, but the blower is not. Not even shure if the rad fans work but the one on the drivers side will come on when the ac is on and the fan is turned on (but nothing blows into the car). I ve checked all fuses and none are blown. Attempted to check relays today, but they seemed OK, not entirely shure. Wires were just temporarily electrical taped for now.
Part 2
Fixed the wiring, and checked it over today, in the area I drilled.
Basically grounded 2 white wires to the rad support, or short circuited the 2 white wires together, no way of knowing which. We checked the relays, swapped them around between headlights, tail lights, foglights, horn, ect. They click on, but do not click off. Havent gotten ahold of any relays that are known to work yet, can anyone tell me if 1g relays are the same as 2g?
No idea if the problem is in the relays or if it travelled somewhere else.
you likely melted some wires together somewhere... i have a 95 gsx parts car, if you end up needing to replace large sections of wires let me know all the wireing is still on my car.
the 2 larg white wires your talking about may be the main power wires to go to the ecu from the Alt. with the battery and fuse box somewhere in between.
gl man i personally hate electrical issues
1 : Pull the ECU
2 : Pray it's okay.
Confirm that and let us know.
To be honest I have no worries about the ECU for 2 reasons :
1) The car is running fine
2) I just bought a socketed and repaired EPROM ;)
Now EVERYONE Keeps bringing up the alternatior fuse, here and on my local forums.
I have not rushed to check it because the battery still charges. But today I will pulll the fuse box and check anyways, and report back!
DOH! it was the 60 amp fusible to the left of the alternator fuse! EVERYTHING WORKS AGAIN :D
Time to resume install on the FMIC now ;) :p
