Shifting problem
DSMnewbie41
Nov 24, 2006
Sterling/newpor, Virginia
Ive searched on this but no one seemed to be having the exact same problem... 75% of the time I'm having ALOT of trouble shifting into first gear..the clutch has to be all the way in and I have to push really hard to get it into gear. 2-5 are perfectly fine and in reverse it will go partially in but then i have to slowly let off of the clutch before it will slip completely in. These problems happen most of the time but not always.
I have the same problem with first, some times I have to let the clutch out a lil or off the brake to make the car roll.
YES! I have the same exact problem, i've broughten mine to 2 dealers near the cities and they have charged me for work that didn't fix the problem. I've had my synchros checked and re-checked their fine, got a new clutch, still same problem, im going to try to adjust the pedal and see if that happens.
Yes i do the SAME thing, i press all the way down on clutch to shift into first, and can't so i lift off the clutch just a little and it goes in. In a few weeks i can reply to this thread and update on the pedal adjustment.
Wow. and here I thought I was the only one in the world with this problem. I have the EXACT same situation as you do. Gonna try and adjust the clutch this weekend, will report back.
