shifting problem
blaze12
127
Nov 27, 2010
St.Charles, Missouri
hey guys my laser that i just bought has a big problem and i cant figure out. so i start my car and push in the clutch and put it into first and give gas while letting off the clutch but once it engages the car starts rocking forth violently and wont stop unless i floor it and only from a deadstop and only in first . please help ........my first manual
ill do that and also my car will not stall sometimes with my foot off the gas and how do i check the motor mounts
Just inspect them. Make sure theyre not cracked or broken, or even that the bolt through it is in! I had my rear mount bolt fall out one time and I had similar symptoms.
