shifter linkage bushing on the tranny
Duke901
111
Nov 29, 2005
Sylvania, Ohio
I noticed my bushings on the linkage on the tranny are lose, Who makes new ones.
got mine from speed-source.net and I also got the shifter base bushings. highly recommend both. you will see an improvement in your shifting immediately
ive heard u can replace them with skate board bearings, anyone else heard about this?
Yep, you can I know a guy who has it done, he recommended that I do it. I plan to here in a week or so. I just got my car back running so I'm having fun not working on it any.
It takes quite a bit of force from what I hear to get them in though, so a C clamp is a must:thumb:
i've heard the problem with skateboard bearings is that you have to weld them together and that leaves a possibility that they will break. i didn't mind spending the 30 bucks on solid brass bushings, and I've had no problem with them ever since
Skateboard/rollerblade bearings work just fine, there is no welding that needs to be done. I would make sure you have a good sanding wheel for your dremel though. You will have to open the hole in the end of the shift cables just a tad bit.
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
  • For sale 1g Kiggly Racing 1G 7 Bolt Flex Plate
    Kiggly Racing 1G 7 Bolt Flex Plate $85 + shipping & paypal fees* these are $175 onlineYou...
  • For sale SBC Organic Clutch Disk
    Brand new organic material disc came from the SBC Stage 3 street K05048-SS-O CLUTCH kit, but I...
    • Mahreeoh17
