2G Shifter Cables
D3monX
263
Jul 3, 2007
Fredericksburg, Virginia
Ok i got a questions about some difference between shifter cables.
I have a 2gb awd talon with a 6 bolt swap and needed shifter cables so i went to the junk yard and got some off a 2gb gst eclipse 7 bolt. i was wondering could that create a problem with shifting, like not be able to go into first gear if its to long or short trying to shift into gear. Should i get awd shifter cables if so would i get the 2gb awd cables or would i get the 1g shift cables because of the 6 bolt?
Thank you for any help that is given.
the ones i took off i didnt even think to check but my question is will the gst shifter cables fit on the gsx or tsi awd.... i can only think no because different transmissions but some say as long its the turbo model its ok but idk
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
