shift linkage help
2G95tsi
Dec 3, 2007
El Centro, California
ok so i was driving my car... tried to down shift into 3rd.. it wouldnt go into 3rd so i just put it into 4th.. continued to drive had to downshift to stop.. stopped, starteded driving again and i couldnt shift into 2nd ### it was really loose and wouldnt enguage, then it wouldnt enguage into 4th either... now its gotten so bad that its permenantly enguaged in 5th gear... the shifter will go up and down freely from 5th to Reverse... my clutch will disenguage the tranny and then reenguage it when pushed in and released.... i had to drive in 5th so i dont think its the tranny ### i was still able to drive just fine... i called my friend he said it should be the shift linkage... anyone have anyother ideas.. and a way to fix it???
If those are tight, check underneath your center console where your shifter connects to your cables and make sure those are connected/tight. One of mine came off once and I hada similar problem.
