Shift Linkage
GreggB
Nov 18, 2012
Columbia, Pennsylvania
I just bought a 90' TSi Talon AWD. The trans was bad so I got a 91' trans from
someone I knew and everything worked great after I swapped the tcase output
shafts. My original shift linkage was also bad so I acquired the shift linkage that
was used in the car that the 91' trans came out of. I hooked that up inside the car
but when I went to bolt the bracket for the linkage to the transmission, I noticed
that the bracket was different than the original. I swapped the bracket and the
linkages are still far too long. So, long story short. 91' AWD trans in a 90' AWD car,
what year shift linkage should I use or do I have to modify something?
I believe that you need the shift linkage, trans, and shifter assembly from a 91+ everything to work correctly in the 90. Wiseman please verify that this is true!
