Shift Linkage and Tranny Problems
ewyss
89
Aug 12, 2010
Martinsville, Indiana
Ok guys im still a newbie to dsm's so i could use some direct help i have tried searching the info to help and found info but none i thought was really helpful.
I have a 92 tsi awd, and i bought the car with a frechly rebuilt tranny it had less than 500 miles on the rebuilt one, it slowly developed a small grind when i went from 1st to 2nd when i was on it at all in 1st gear or if i down shifted into 2nd from third. I decided to put new shift bushings that were brass and not rubber since i got them for free and then the problem got worst it does the same thing but now it wont even go into first i have to launch from 2nd gear. if anyone knows what the problem could be please let me know. thanks
first and second utilize the same shift fork, your shift fork might be bent or damaged.
If thirds and 4th shift fine then I do not think it is your linkage. When you completely depress the clutch pedal does it disengage the clutch? Your clutch might not be releasing, this could cause your gears to grind.
goodluck
Yes it wont go in at all if it isn't releasing all the way. Can you get it in first if you turn the car off?
need a little more info.
did you replace the bushings at the transmission or the shifter or both? are you pushing the clutch all the way to the floor? Once you get going, can you rev match first gear to put it in that way?
is the clutch feeling sluggish? check the fill on it? anything else simple, check it first before moving on to the trans itself. Doesnt really sound like it has anything to do with the bushings really if it will go into other gears but, hard to tell at this point.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
