Shift bushing
akasoldats
36
Nov 17, 2008
Kzoo, Michigan
The previous owner of my car replaced all of the bushings that connect to my shift lever with some make shift garbage and now its all worn out. Its to the point that I shift and cant tell what gear my car is in. Does any one have these pieces I've looked and the junk yards around here suck. Or a do it yourself fix?
Skateboard/rollerblade bearings work for the 4 corners, as for the middle piece I can't help ya.
The skate bearings are replacements for the plastic bushings at the transmission side of the shift cables.
The four corners are rubber bushings that can be replaced with washers or the more expensive "symborski kit" which doesn't do anything more except sound foreign.
And searching for parts to replace on the shifter assembly is usually more time consuming and more expensive than to just replace the entire thing. It can be had for $15-$30 from a junk yard or less from a private seller looking to part out their car.
