2G Shift Boot?
Removed the trim around the stereo, just pry it off. There's 2 screws under there to remove at the top of the center console plastic. Remove your cup holder assembly, 2 more screws. On each side of the console, around the seat belt area, there's another screw, 2 total. Unscrew your shift knob. Lift up the console, but don't just yank it. Unplug the cigar lighter, make note of which wire goes where. There may be a light plugged into the ash try that most use for change. After the console is out, flip it over and the boot is held in by a plastic retainer. Pull the 4 screws out of the retainer, and swap the boots. Install is the reverse of everything here.
