shaking boost gauge needle on vacum
96Tsi
Sep 16, 2005
North Olmsted, Ohio
I just installed a boost gauge and a manual boost controller on a 2g talon. I'm running 16 pounds boost. When I'm in park i read about 18 pounds of vacuum. But when i put it in drive and hold the throttle steady any time below 2000 rps the needle shakes up and down very quickly in the vacuum side as wide as 8 pound notches until i hit 2000 Rpms and the needle goes right to zero and smooth on up boost with acceleration. Now i know the turbo is set up to kick in at 2000 rpms but why does the needle shake so radically on vacuum below 2000 rpms?
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
