boost gauge needle sticking
daveyfx
236
6
Dec 21, 2004
Orlando, Florida
As the topic states, the needle of my boost gauge is sticking, as in it is slow to respond.
When I installed the gauge initially, it was just fine. I would fire up the car and a second later, the gauge would read vacuum.
Several days after installing the gauge, I noticed it was very slow to garner an initial reading. Now I have to wait about 2-3 minutes for the gauge to go from 0 to a vacuum readout.
Replacing it is out of the question since it is a discontinued Defi D-gauge gauge.
Help!
Hmmmm thats weird, id ###### just go buy a new one. I no you probably dont want to hear this but you can get boost gauges for very cheap on ebay or in the classified section.
What I'm more curious to know is if the sticking issue will gradually worsen and cause the gauge to become inoperable. If it won't then I'll keep the gauge and deal with it.
It doesn't seem to stick when the car has been sitting for several hours. Only if I let it rest for a couple of hours (or less) will it stick for a minute or two.
:mad: :mad: :mad:
:mad: :mad: :mad:
Well, if that is going on, I'd swap it ASAP, if it's sticking, you may not be getting an actual boost reading, which could make life very bad for you. Just go with an autometer gauge. IMO, you won't find a better quality gauge. Inexpensive as well.
What I mean is it will sit at dead zero for up to a couple of minutes and then read vacuum. I know that it is reading correctly after it budges from zero finally :)
So I noticed a new and interesting issue with the gauge today:
Occasionally, after running the vehicle I can shut her down, watch the needle float back to zero and then restart the car. Now when I do this and shut her back down while the needle is at zero, the needle will quickly fly down to vacuum and then float back up to zero just like it should when the car is shut down.
Could I have botched something in the install possibly?
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
